timming issues
I know yall have got this kind of question before but i am having a problem with my timing on my 454 bbc. Its the 454 HO out of jegs. Its pretty much a stock 454. it will only run with the timing set around 55 degrees. And with the timing set that high it kills starters and flexplates. the distributor is a mallory hei with full lock out. it has no mechanical advance nor vacume advance. Its out of a race car. Im wanting to know how to get the timing down and making the motor start and run without it backfiring threw my carb or dogging out on take off. if yall have any input please feel free to give me some.
Check the firing order to be sure the timing light isn't firing off the wrong terminal. It sounds a lot like the cam is off a tooth (out of phase). The quickest way to check this is to either remove the timing cover and look to see that the dots are aligned, or degree the cam. If the dots on the timing gears aren't correctly aligned, simply correct them. If you don't want to remove the cover or the dots are in alignment and you still suspect the cam is out of phase due to a manufacturing error, use the intake centerline method of degreeing the cam. This isn't the most accurate method but it is the quickest and will tell you what you need to know. Details on using the intake centerline method is about 2/3 down the page: http://www.compcams.com/Technical/In.../Files/145.pdf. Good luck |
The 454HO is not a good motor to use a locked out distributor on.
Get a distributor that has a functional mechanical and vac advance system. Get the required GM OEM starter motor support bracket too. 454 crate motor timing 32 to 38deg at WOT max mechanical advance ( depends on the fuel octane used) typical timing with a typical 20deg mech timing curve will be 12 to 18deg initial at idle and 32 to 38deg at max advance. anything beyond 38deg @WOT is too much. vac advance should add 8 to 12deg more timing at part throttle steady cruise to a max of about 15deg. It up to you to install and run this engine correctly. Including fuel and timing. What you are doing is considered owner abuse and voids the warranty. Get it together. |
| timming | Bronco75 | Engine | 3 | 11-09-2012 04:11 PM |
| help with timming | 84trans-am | Engine | 27 | 07-25-2009 04:13 AM |
| help with timming | 84trans-am | Engine | 3 | 07-21-2009 12:24 PM |
| timming | gtoman222 | Engine | 2 | 10-05-2006 07:42 PM |
| Now my timming! | loperlopez | Electrical | 4 | 08-17-2004 01:18 AM |
