I have brought this up before. Today I was cutting some sheet metal and I thought I would bring it up again. I do so because I am still amazed at how I can cut a straight line in sheet metal as long as I want with this little pair of offset tin snips. I am not kidding, you could cut an eight foot by four foot sheet of metal in half with this little $25 tool. When I think of how long it took me to figure this out! I bought all the tin snips and shears that I could get my hands on that said it was for a straight line. These "Offset" snips are made in both "left" and "right" versions. I think this is where I got confused, "left and right" doesn't sound like "straight" line to me!
Well the thing is they will cut around a corner just fine and you need the left and right cut so you can go in that direction too. A quality pair of these offset snips will shave off a mm wide piece of metal without distorting the metal!
They handles are color coded with the yellow being straight, the red being left hand cut and the green being right hand cut. I VERY rarely use the straight ones, the offset seam to do everything I need.
The long cut I did was kinda crude so it may not look perfectly straight to you. But if you have a straight edge drawn line you can cut RIGHT ON IT making a cut darn near like a shear. The photo with the long cut is the one that has the pair of offset snips on it. The other snips are for example of other types.
Brian they are also called aviation tin snips....supposedly invented for aviation sheet metal work, I worked in the aircraft industry most of my adult life and have heard all kind of descriptions for the reasons for the way they are made and used......for use by right or left handed people ,to make right or left cuts in blind areas of aircraft,to make right or left cuts in sheet metal to make complex curved objects. But yes you are correct in saying they make excellent straight cuts, in fact those are the only cutters I have ever used in the sheet metal work that I have done, using them to cut large sheets of metal untill I got a foot shear.
Kenny
I don't know the terminology and most scary I write something all jacked up on passion to get it to the board and could miss something. But I am with you, I use my left hand offset probably 95% of the time with my right hand pair 4% with the reminder of them the last 1%. I also have a cheapie "shear" I got from Eastwood or low buck tools or something like that years ago.
It "works" though honestly the offset snips do a better job for most projects.
Brian I also had a" throat shear " that was very similar to what you have pictured ,I never used it much cause it weighted more that a VW Beetle ,and had to be mounted to a bench so it was not portable .A man that came in my shop saw it and offered me a 100 bucks for it....so I let him have it only to find out later that model sold new for close to 500 bucks! ...Oh well I didn't use it much but it did do real nice curves in sheet metal and it was alot easier on these arthritic hands.
Kenny
A company by the name of Pro-Snip used to make offset snips like that. I used them a lot in a sheetmetal fab plant I used to work for. I still have the red handle ones - the green ones gave out on me a few years back. I wish I could still find this brand because for me they work the best.
Brian, I bought another good set of Irwin tool tin snips last week. They beat the heck out of the harbor Fright ones I had been contending with for quite a while. I generally just grabbed my grinder for cuts, now I grab my snips. Thanks for all the knowledge you share with us so graciously.
I have to tell you, for any precision tool Harbor Frieght BLOWS. A high quality tin snip like Wess or Irwin or the like are SOOOOO much better it isn't even funny.
Left hand offset snips are made to cut straight and cut curves to the left. Rights cut straight and cut curves to the right.
Snips marked as straight cut are only good for making short cuts from an edge, like cutting a notch in sheet metal.
I've owned about every major brand of offset snips on the market, and my favorite brand is Midwest. http://www.midwestsnips.com/products_subcategory.php?sub_id=45&cat_id=1
A lot of the snips on the market with other names are made by Midwest with private branding. At one time Snap On was selling Midwest, but don't know if thats still the case or not.
The pic Brian posted is of a Proto branded snip, but I'm pretty sure its actually made by Midwest based on overall appearance.
Wiss offset snips are decent, but not as good as Midwest IMO. The Wiss offsets are shorter and more stubby, and just don't feel as good in use.
Klenk is another big brand of snips, but I've never run into anyone who likes their offsets. I had one set of them, given to me in near new condition by a buddy who said he hated them. Later, I gave 'em away too
Don't know if they're still made or not, but Wiss used to make a pair of snips that cut out a narrow strip of metal by using 2 upper blades with a lower blade between the two uppers. They're really handy in some applications because they'll cut with the least distortion of any type snip.
Theres a snip that uses the throatless shear desigh that wont make those curly Qs or want to bend one side the steel up or down,I want to say pro shear but I'm not sure...
Glad to see ya workin on that rambler Brian
.....ahhh my favorite tin snips. I have all three - straight, left and right. Had 'em for probably well over 20 years. The straight ones are dull, so I do need to cough up some bucks for some new ones.
I also have these and they do an even better job of cutting a straight line without distortion, but do leave a 1/16" curly cue. http://www.jilson.com/shears.htm
I bought a good used Black and Decker model 3210 # 12 elecrical shear, I was helping my son and a piece of flat stock had a tab on the back I didn't see and I broke the bottom edge cutter, They wanted $ 75 for the little 1/2 square cutter die, I bought the HF tool they copied for $ 30. and it works just fine I use the hand snips to start a cut then finish with the Elect shear, I have clamped a piece cut straight with a shear for a guide.
Dave, I have one of those, and the electric shear Tim, both have their place that is for sure. I forget I have that darn electric shear, traded the MAC dealer for a used tool box I had and I forget I own the shear, darn thing is like new! I need to put it out where I can see it. The little blind snips you posted Dave are killer if you are working in a small area. Cutting a hole out for a tail lamp or something where you need a 2" oval or something, they are REALLY hard to beat.
Thanks DBM, I have been getting out there and working on it every single day, sometimes even before I go to work in the morning. This time change SUCKS with it stone dark when I come home from work. The car is out side you know, garage full of other projects.
It is getting close to rain and I need to get this sucker done NOW.
Besides, I love this stuff, I don't work on any old stuff at all anymore at work so at home is my only time to play. Last night I re-engineered the upper tie bar to be removable. That was one thing where AMC had their head up their butt. The motor had to be dropped out the bottom (after removing the suspension lower crossmember) and the removal of the radiator required the removal of the front bumper and grille panel with hood latch and what not! So not it is like a normal car and I can simply unbolt the tie bar and get it all out. It's nice having a parts car so I got the tie bar out of it cutting it longer and overlapped it over the "subs" from the original.
In the second photo I am holding the tie bar so you can see how it fits onto the portion of the original.
"I love creating something that didn't exist yesterday"
Brian Martin
I'm working on putting a new furnace in the 100 year old farm house and we have snow this morning. a lot of times it's easier to turn the snip over and cut from the bottom. it;s easier to see your line and the angle of the handles makes it easier to squeeze. I have a U shaped 3 sided guard rail . 3 ft X 3 ft X 3 ft. made from 1 in sq tube I drag into the shop . I lay the sheet on top and have good access to reach under to work.
I am with you, but again, the snips may be easier to use upside down because you have the wrong one. I am just saying that if you are holding the "left hand" snips (red handle) in your right hand and cutting you can see the line perfectly well and it is "ergonomically correct" so there should be no reason it would feel any better any other way.
Just something to think about, not saying you are wrong but it may be problem.
Midwest are pretty rare here.
WISS are a long established brand of aviation snips with good quality.
Occasionally tried others and always regretting it.
If you cut with the aviation snips you'll notice this:
1. Straight cut (yellow handles) will "push" the metal on one side up, the other side down.
2. Left and Right cut (read or green, don't know right off which is which) will only "push" the cut metal up on one side (the left or right) and the other side will remain straight. That's what the left and right cut means. Easier to cut curves with the metal only going "up" on the waste side.
3. In some cases you might need to cut upside down so the metal you need to not be distorted is on the flat side.
That is what I don't get Frank, with the offset snips as I displayed in my photo there is NO distorted side!
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
