Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tintable primer
Thread: Tintable primer
Old 10-30-2005, 05:35 AM
mrcleanr6's Avatar
mrcleanr6 mrcleanr6 is offline
your going to be much better off priming the car normally then mixing up a flat acrylic urethane whatever color you want and shooting that. it will be much more durable and it will last. except for epoxies, primers dont seal and allow moisture to go through them. you will just be redoing it again in 6-12mos. goto your jobber and he can mix you up any color in any sheen. he should have both color and sheen samples.
