Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tinting epoxy?
Thread: Tinting epoxy?
Old 11-02-2010, 09:52 PM
crashtech's Avatar
crashtech crashtech is offline
Last wiki edit: Epoxy primer
Wiki Edits: 17
Originally Posted by cjperotti
At a reduced mix, yes, by the manufacturer. However, Some paints aren't recommended to be applied over epoxy primer by the respective manufacturer of the paint. Therefore, you're taking a risk by not checking the paint manufacturers tech sheet. Just because the epoxy manufacturer makes a recommendation doesn't mean it will work for all paints. That's the main reason I don't use or recommend it as such and advise others to exercise caution when doing so.
Doe's that explaination clarify it for you?
I'm curious to learn about these products which shouldn't be applied over epoxy. Are they waterborne? lacquer? Can you provide links to some tech sheets that support your assertion?
