Tinting Hot Rod Black with 2k primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2009, 10:56 AM
Is it safe to tint the eastwood hot rod black with the martin senour crossfire 15222 2k primer? he wants to make the hot rod black a little less black. i'm pretty sure that the 15222 is a urethane primer (the tds doesn't say). it does not require a sealer when sanded with p600. the ratio will be very low, probably something like 1:100 primer:black.
Old 04-20-2009, 01:28 PM
New Member
primer
have you tried zero rust primer? this is the best out there. it requires only a hand tool to existing rust and also zero rust prep, it is a powder mixed with water and it will condition the metal to ph6 perfect for painting, ****************** for more info, i am the distributor is you want to purchase
Last edited by OneMoreTime; 04-20-2009 at 01:46 PM. Reason: Advertising. Please see: commercial posting guidelines.
Old 04-20-2009, 01:49 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I don't think I would like to try that as I believe the Eastwood is acrylic enamel..those 2 materials would not do well together..+ making black lighter can be a bt hard to do..if you have some Eastwood white now that could work..
Sam
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
My First Hot Rod!... project TexasTechX1 Hotrodding Basics 46 04-21-2009 07:40 AM
Hot Rod Art Book futureelements Hotrodders' Lounge 1 02-06-2009 05:33 PM
2K aerosol can filler primer review. MARTINSR Body - Exterior 15 09-05-2008 09:59 PM
2k Primer, to Wet? satexasf150 Body - Exterior 2 05-19-2007 10:13 PM
