Tiny tiny solvent pop? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-01-2011, 09:45 PM
302 Z28's Avatar
I vote for solvent pop. Sand them out then place the car or part in direct sun for an entire day before re-coating. When re-coating mist on the first coat then extend the flash time for the second and following coats.
Vince
  #17 (permalink)
Old 03-01-2011, 10:08 PM
hmmm. Thanks for the replys.
In a way I would be suprised if it was solvent pop because it was a really warm day when I painted and I let it dry for atleaset 30 min between coats.
To be honest my airline filtration system is a bit slack, it only consists of a copper tube spiralled through a tub of water and a water trap. I was wondering about that "iso clumping" issue. Why is this never mentioned in paint defect guides and data sheets?
Do you think its the humidity in the booth or in the airline thats more important?
  #18 (permalink)
Old 03-01-2011, 11:44 PM
I think it depends on what you mean when you're saying 'more important.'
I wanted to spray my SPI epoxy on a warm (but not hot) humid day. I called Bruce and he said my conditions were perfect because it wouldn't make the solvents flash too fast. So, to an extent, some humidity can be a good thing. According to Bruce.
  #19 (permalink)
Old 03-02-2011, 01:02 AM
oops I meant Barry, not Bruce. Bruce is the suspension expert I talk to.
  #20 (permalink)
Old 03-02-2011, 02:27 AM
Just an update, I did some wet sanding to find out whatís going on, they definitely stick out from the paint surface but then also seem to have a crater in the middle.
So maybe they are a fine solvent pop, the fact I sprayed on a hot humid day may have caused a skin to form to quick.
Its annoying that I didnít record the temp/humidity from my weather station that day because I still donít know when I should stop painting in certain conditions.
  #21 (permalink)
Old 03-02-2011, 05:59 AM
Derkyb's Avatar
Trust me when i tell you its moisture in the lines/air! I wouldnt be so sure if hadnt happened to me last week. It looks like tiny craters but there are some that have nibs and in the light it looks like a mettallc paint job, I bet when you sprayed the first coat of base it looked like i was going to fish eye but then easily covered with the second coat. I sanded and recleared also and it helped but was still there. I was confused too because it didnt always happen with all components being the same. It depends on the weather and how hard you work the compressor. To test it get one of those dessicant filters(not harbor freight they dont let air flow through) with the windows at the gun and watch them go from blue to pink before you finish your second coat
  #22 (permalink)
Old 03-02-2011, 06:45 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I paint when it's raining and the humidity is 100%,
I prefer to because I get cleaner jobs.
I've never had a problem with humidity, other than having
to wait longer for flash times.
  #23 (permalink)
Old 03-03-2011, 07:53 AM
302 Z28's Avatar
A rainy day helps to hold down the dust and trash, perfect dy to paint.
Vince
  #24 (permalink)
Old 03-03-2011, 11:16 AM
I've seen something similar with 2K clear when I've used my infra red dryer too soon after spraying.Basically the paint dries to quickly.It always flats out and buffs up
  #25 (permalink)
Old 03-07-2011, 03:46 PM
It turns out it was solvent pop (or atleast something that causes little craters), after sanding with 1200 grit to 2000 then buffing there are still little craters there. I think it may have been the fact it was a very hot day when I was painting.
  #26 (permalink)
Old 05-03-2011, 08:03 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Just painted a buddies honda prelude last night and got the same results using Nason singlestage. Needless to say I was pissed cause this is a super cheap paintjob for him. Glad to hear the wetsanding helps alot,
Could you put a V-twin in a tiny car? lumberjacknooj General Rodding Tech 54 04-12-2013 07:40 PM
Tiny pickup trucks? lumberjacknooj Hotrodders' Lounge 15 03-06-2008 09:35 PM
Tiny bubbles in paint!!! AlanTA Body - Exterior 6 09-08-2004 08:31 AM
Tiny Cracks SWAMP DONKEY Engine 4 11-04-2003 10:32 PM
tiny spots in ABS painting plz. help mkjeswani Body - Exterior 2 06-23-2003 03:14 PM
