tinysts
Hello I have a lot of gas gages and a lot of sending unites for then the only thing I am having a problem with is when I hook them up they stay on full. My question is is there a way to reduce the ohms in it and if so wich one do you reduce, or what can be don to make them work.
Doc here,
Are these Gauges and sending units loose .. or mounted in something? Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Your gas tank sender is probably not grounded........
Ontario Rodders |
tinysts
These gauges are not mounted to anything yet, just testing them. Same with the gauges.
Doc here,
Get a BENCH POWER supply, (not a charger) , OR a 12 Volt Coleman Lantern Battery, (DO NOT USE THE CAR BATTERY..If you get a short you can injure yourself or start fires or explode a battery) ![]() Locate the Power , Ground, and Sender sides of the gauge..Most are marked "S" , "G" and "I".... I is power to your source.. "G" Is ground. "S" is sender.. Run a ground wire from your supply or battery, to your SENDER BODY, and the sender signal wire back to the "S" terminal.. Power your system up, (advise a 3 amp fuse) , and note reading on the gauge, It should be "E"...Than raise the float slowly and watch the gauge...1/4 travel should be 1/4 index increment..1/2 travel should be about 1/2 index increment..and so on until "F".. If it full scales or does not respond with little movement, try one of the other's...If it seems to track OK, with , say an error in the middle or 1/2 tank it may be OK, with a linearity problem..not a whole lot you can do about that..except try and bend the float to make it a bit closer OR just make a note of the non~linerity..and keep it with the system when you install it. Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 07-27-2006 at 05:14 PM. Reason: I before E...Except after a 12 pack... |
| tinysts | tinysts | Introduce Yourself | 2 | 07-23-2006 11:13 PM |
| tinysts | tinysts | Introduce Yourself | 2 | 07-12-2006 02:12 PM |
