That is a very good one that is missed by a lot of guys. I have a small, cheap awl on my bench right along with the can opener. They go hand in hand with the light rubber mallet as the three tools NECESSARY to work with paint cans.
Brian |
That is a good one that I do. Also when you have a full gallon of paint it can be a mess to pour. They actually make a plastic peice that will snap on to the top of the can for aid in pouring, but I always just use a peice of 2 inch masking tape taped on the edge so half of it is stuck to the can and half of it overhangs the edge of the can. Or after you have mixed it well you can pour half the can into another container to make it easier to pour and handle when it comes time to mix and pour into the little quart cup for the spray gun. At home depot and walmart in the paint sections they have mixing cups for measuring paint with the amount of ounces printed out on the side of the container.
For getting the paint out of the can and into the mixing container,, I use a lattle type dipper, it has a 'V" shaped side on it and works very well, ,without getting paint all over the edges of the can , and makes it easy to get the correct amount of paint in the mixing container,, and if you dip out too much,, its easy to put back in the can,,the hole in the edge is a very good idea too, Thanks
Mixing Containers
#36174 1 qt. pail #36175 lid for above #36170 1 pt. pail #36171 lid |
yeah, they also have the quart mixing cups at the paint suppliers also, we had ones with ppg logo on the ones at my last job, lots of places to get them. Also nice to have the paint sticks with the marks for different mix ratios like 4:1:1.
Speakin of mix cups, I picked up a box of mix cups the other day and my supplier had some new lids with built in strainers. I can see the advantage of pouring out strained paint directly from the mix cup especially with small touchup guns. These cups were made by EZ-Mix. Anybody here using them? Paper strainers are cheaper though.
| Rich at idle but pinging on tip in? | JoeS | Engine | 24 | 02-21-2006 08:02 AM |
| Bad Day just got worse! | Novaman78 | Hotrodders' Lounge | 31 | 11-15-2004 08:13 PM |
| Engine Vacuum is showing 10 and no higher? | ataririder | Engine | 42 | 02-18-2003 07:12 PM |
| Madd Santa's 12 days! | Madd Syntst | Hotrodders' Lounge | 4 | 12-21-2002 11:49 PM |
| 10 0/0 theory | dinger | Hotrodders' Lounge | 3 | 09-12-2002 08:14 AM |
