Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 09-30-2005, 11:21 AM
kenseth17 kenseth17 is offline
tip of the day #13.999 ahh heck, lets just make it 14
When I was working on a mustang, I couldn't find the door lock gaskets and also couldn't find one of the gaskets for the door handle (which I later found) so I made my own as I didn't want to wait and send off for them (yeah I could have just probably cut some out of a piece of something, but the one for the handle has an impression and the outside of the gasket fits around the outside of the handle, so it is not a flat piece. I don't think there was door lock gaskets when I got the car. This would also work for other small things like hood bumpers, ect, and I've even copyied model cars this way. First you need to make a part that will be copied (or already have the part to copy). I cut the shape of the door lock gasket from a piece of soft plastic about the thickness I wanted from an outline I found on the web. Once you have the part made you want to copy, apply a wax (I used some paste floor wax) for mold release to the part and place on a piece of waxed paper on a hard flat surface. Then you need a box or something else slightly larger then your part. I used a cap from a jug of cleaner. Mix up some plastic filler and fill the cap, plaster of paris would also work, and while its still wet tip it over on top of the part and leave it harden. Now you can remove the part you used to make your mold and you now can make copys. I used some flexible bumper repair material I had around to make some gaskets, but you can use whatever material you want. Just make sure you wax the mold you made before making your duplicate parts. More complicated parts the mold would have to be split to remove it from the part you are copying and also to get the parts you make out of the mold. This could also be used on a larger scale to make a fiberlass part or maybe a repair peice for a corvette, depending on your dedication. Something larger you would build a box around the part you want to copy, and fill it with plaster to make your mold. Then you can wax and lay fiberglass up inside the mold to make your peice.
Old 09-30-2005, 01:24 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Yup One of those Moderator's
 OneMoreTime's barnstar
Wiki Edits: 3
re: tip of the day #13.999 ahh heck, lets just make it 14
That is a cool idea..I like the part about making glass parts from a mold like that if a fellow has a good piece to work from..
OMT
If it don't work it ain't pretty!!!!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "tip of the day #13.999 ahh heck, lets just make it 14"
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 03:09 PM
Tip of the day number 9 MARTINSR Body - Exterior 4 09-17-2005 08:04 PM
Tip of the day #7 jcclark Body - Exterior 8 09-16-2005 05:05 AM
Tip of day #6 BarryK Body - Exterior 18 09-12-2005 07:16 PM
Tip Of The Day #2 jcclark Body - Exterior 13 09-02-2005 05:01 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
