Tip Of The Day #2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2005, 10:07 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Tip Of The Day #2
DISCLAIMER: The tip of the day is not intended for mature audiences.
If you are a "Pro" with all the tools and products at your
disposal please disregard the following. If you're a newbie
or cheapster like me you may like it.
Tip: When you want to protect your tires because you're to lazy to
remove them, use a plastic garbage bag. The kind you use for
the kitchen. They are a little small but if you cut the back up
about two thirds the way you can stretch them over the wheel
and cover it completely. Don't reuse them, they flake paint easily.
If your tires are too large use a leaf bag.
Old 08-31-2005, 10:11 AM
astroracer's Avatar
Good tip... I've been doing this since the late 70's... After painting I stuff all of the removed masking paper into the bags for disposal so they have two uses...
Old 08-31-2005, 10:13 AM
jcclark's Avatar
The Penny Pincher
Thanks, I do the same. (should of rememberd that)
Old 08-31-2005, 10:17 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Two great tips! I will remember them. Thanks!
Old 08-31-2005, 11:00 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
i use old tshirts .
Old 08-31-2005, 11:11 AM
rrmccabe's Avatar
GM Muscle
Originally Posted by shine
i use old tshirts .
I use my wifes T-shirts
Old 08-31-2005, 11:48 AM
jcclark's Avatar
The Penny Pincher
My wife's are to big for that
Old 08-31-2005, 12:42 PM
rrmccabe's Avatar
GM Muscle
Car cover?
Old 08-31-2005, 02:37 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I've used sheets blankets and or quilts when spotting on a fender to cover the rest of the car
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 08-31-2005, 06:03 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Masking paper works well if you dont have wheel covers
BK
Old 08-31-2005, 07:47 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
That would make it very hard to concentrate on the painting.
Old 08-31-2005, 08:11 PM
I've been using garbage bags to cover tires for a long time. I use the 30 gallon size and with enough pushing they will slide over an average size tire. Or if you get the garbage bag to stretch a bit they will slide over.
Old 09-01-2005, 08:33 PM
73oldsman's Avatar
I use the new twist tie top trash bags by Glad. Place them across the front of each tire with opening at the 12 and 6 o'clock position. Next, get in the car and pull forward 1/4 tire rotation with the opening now at the top of the tire. Pull bag opening up, gather it together and use the convenient twist tie to seal the bag closed. Voila, the tire is sealed in the bag and there is no tell-tale streak of paint around the bottom of the tire where the other bag flipped up off the floor while painting! Remove bag in reverse order of installation. Also, the bags can be reused for trash by turning them inside out and filling with trash as needed. P.S. Be sure to remove the bag from the tires before driving!!! yuk,yuk,yuk!!!
Old 09-02-2005, 05:01 AM
jcclark's Avatar
The Penny Pincher
That the neatest thing I've heard yet!
You guys keep elaborating on these tips and I'll keep trying to come
up with some. This is how we learn the stuff others do on a daily basis
that they take for granted as common knowledge,
To someone else it's a great tip.
It's amazing how many different ways we can come up with!
Tip of the day jcclark Body - Exterior 20 10-07-2006 06:50 AM
Gun tip size VWFan Body - Exterior 9 03-22-2005 12:29 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
Gasoline Blackout Day Is Wednesday, May 19, 2004 - From The Desk Of Richard Piet Super Chevy Hotrodders' Lounge 41 05-20-2004 05:22 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
