Tip of The Day #43
Tip of the day:
For HVLP guns like mine whose air requirements are toward the low side this assembly works really good. Connect air fittings to a tee and install a gage. Connect the assembly to your gun and regulate the pressure at the compressor to get what you want at the gun (trigger pulled) Then you can remove the assembly and have the right pressure without all the hardware of a regulator, gage, etc. But, like I said, if you need to really crank up the pressure at the compressor to get the gun right, this may not work for you. It works for me with larger fittings and 1/2" hose, and a gun that only pulls 10 cfm.
Very good tip
![]() For those of you that need higher PSI for workshop tools, have an extra regulator just for your gun hose, and adjust it's pressure as above. I use one of these with a SATA regulator inside the booth, so I can drop gun pressure to 2 Bar, whilst leaving the workshop tools getting 'full pressure'. |
| Tip of the day #24 | MARTINSR | Body - Exterior | 32 | 04-12-2006 10:22 PM |
| Tip of the day #25 | jcclark | Body - Exterior | 12 | 11-17-2005 08:28 AM |
| Tip of the day #25 | BondoKing | Body - Exterior | 7 | 10-29-2005 01:14 PM |
| Tip Of The Day #2 | jcclark | Body - Exterior | 13 | 09-02-2005 05:01 AM |
