Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tip of the day number 9
Old 09-17-2005, 08:04 PM
mrcleanr6's Avatar
mrcleanr6 mrcleanr6 is offline
working as a marine mechanic for some years you also learn a few things about removing frozen bolts. if you have a screw or bolt where the head twists off, get a 12 point socket that is a size smaller than the threads and hammer it onto the shaft of the bolt. heat with a torch as brian suggested and turn it out with a ratchet.
