Tip on keeping custom made Valve Covers Clean - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2007, 09:10 AM
rac43's Avatar
Thought I'd let anyone know thats interested, I have a set of custom aluminum valve covers, satin finish and I keep them looking like new with Orange Blast. I use a soft rag and spray the liquid on the rag then go over the covers. Works like a champ. By the way, any orange cleaning liquid will probably work the same. I have no connection to orange blast.
Old 06-13-2007, 09:20 AM
coldknock's Avatar
Almost all of the generic cleaners without ammonia or acid work just fine on aluminum. I agree that the citrus based cleaners seem a little better, maybe 'cause they smell purty.
Larry
Old 06-13-2007, 11:12 AM
speedydude's Avatar
Registered Cruiser
My compliments on the clean look of that "T".
I've got some aluminum I'm going to try that on.
Question........you've removed and blocked off the mechanical fuel pump. What is right above it?? The electric pump, press. reg., ,it's hard to make out from the picture. Thanks, John
Old 06-13-2007, 12:35 PM
Mustangsaly's Avatar
rac43,
you have a Great Looking Ride & engine !
not to high jack your thread but,
I like the sheet metal valve covers. did you just polish a set of aluminum sheatmetal V covers and add the grommets for the pcv valve your self ? is there anything in the other V cover ? is there baffles on the under side of the pcv valve ? I want a set of aluminum sheet metal V covers on my SBC street ride. and was thinking of putting a baffle in each V cover if needed. do I need a baffle under the pcv valve ? do I need a baffle under the breathers ? there will be a pcv valve in one cover and a breather in one V cover, maybe both. any help would be appreciated.
thanks
Mustangsaly
valve covers blown off deno Engine 32 07-22-2009 08:53 PM
Fake Hemi Valve Covers Chev37 Engine 10 01-27-2006 04:13 PM
EGR Valve in the way of new valve covers Jag Daddy Engine 9 05-16-2004 11:05 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
custom chrome valve covers sidtracy Engine 0 09-01-2002 02:24 PM
