tip on panel trim 4 hotrods - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2013, 12:25 PM
I use Bear Claw latchs,like many hotrods,but the little handel { I use a drowr pull] needs some trim around it,so this is what I used. I think other Co. also make def ones but it the idea I'd like to pass along..
The little trim for around the inside door nob is one of these things,I only used 1/2 and made it press in to the door panel with a small bit of glue.
ID:	108849   Click image for larger version
Old 12-27-2013, 01:51 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Whatever works, works, but you can also look at plumbing pipe escutcheons: Escutcheons, hole covers, smitty plates, shower arm wall plates
Old 12-27-2013, 02:37 PM
Good ideas Dan! ,I picked the one I did because of the size,I didn't care for big around,but needed a 1in. ID.
Old 12-27-2013, 08:19 PM
Wiki Edits: 22
Always something to learn here. Still, your post was information we didn't have.
Trim panel board material? MARTINSR Interior 30 10-05-2013 02:25 PM
1964 Impala SS Bucket Seat Trim vs 1963 Trim ? 64Joker Interior 1 12-29-2009 09:51 AM
roller tip to valve tip alighnment eliot Engine 5 07-31-2007 01:33 PM
1985 Monte Carlo Windshield trim and rear windshied trim removal ChrisMiddleron Body - Exterior 3 01-14-2005 07:20 AM
cracking where fibreglass panel grafted to metal panel goldstarr Body - Exterior 2 11-22-2002 07:44 AM
