Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tip for a smelly garage!
  #18 (permalink)
Old 12-04-2012, 06:07 AM
Curmudgeon29's Avatar
Curmudgeon29 Curmudgeon29 is offline
Now that wasn't so easy!
Originally Posted by Curmudgeon29 View Post
OK! This was this mornings project. Still smelled gas, off came the canister.
I came off the curley-q with 3 loops as high as and behind the tank.
Then I dropped through the floor and attached a fuel filter with 1/4"
fittings then from the filter a 3' line terminating in the frame rail.
This afternoon it was 84 degrees---No smell!
This does seem to work! When I first park the car, you can smell some gas, probably from the carb. But it dissapates and no smell!
Looping the vent hose then installing a fuel filter on the end works for me!
