Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tip for a smelly garage!
  #19 (permalink)
Old 12-04-2012, 07:40 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Originally Posted by Curmudgeon29 View Post
This does seem to work! When I first park the car, you can smell some gas, probably from the carb. But it dissapates and no smell!
Looping the vent hose then installing a fuel filter on the end works for me!
You will get a bit when you first park the car from both the carb and exhaust - a non EFI car, unfortunately has these 'gas leaks'. This is especially true with an aluminum Edelbrock Performer carb, and somewhat worse without a phenolic spacer to shield it from the engine heat. But this system works
Dave W
Irelands child
