Tip for a smelly garage! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2012, 07:17 PM
Curmudgeon29's Avatar
Now that wasn't so easy!
My wife has complained for sometime now about the gasoline smell in the garage, so I have been trying to find a cure and I think I have!
Both of my cars have a 1/4" ID vent hose from the tank top exiting under the car.
I found a Dorman #47149 vacuum check valve in the Help Section at my parts store. It's very small and fits the 1/4" line.
It draws enough air while driving and doesn't restrict fuel flow.
The Smell is Gone!
Old 11-19-2012, 08:07 PM
Expandtion could flood carb I suppose, contraction just sucks air thru check valve. I need suggestions on a small charcoal canister, maybe for a motorcycle.
Thanks!
Old 11-20-2012, 06:48 AM
35WINDOW's Avatar
Last journal entry: Engine!
I was concerned about this too, and, since I don't have enough Vacuum for the Cannister that was out. I took a tip from Ireland's Child and put two loops of Hose after the Tank (above the Tank), and, I put a small Ball Valve at the end of my Vent Line so that when I put it away I will shut it off-not the sexiest of solutions, but I think it works-
The Following User Says Thank You to 35WINDOW For This Useful Post:
Curmudgeon29 (11-24-2012)
Old 11-20-2012, 10:15 PM
bentwings's Avatar
bentwings
I use a standard gas line filter on my vent line. No problems at all.
Originally I had intended to use a charcoal system out of an early 80's GM but this worked very well instead.
The Following User Says Thank You to bentwings For This Useful Post:
Old 11-20-2012, 10:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have used this same thing, have one on my DD Malibu wagon as we speak. Just tuck it out of the way, pointing down so no water, etc. can get into it. But my car is outside so I don't know how well this would stop the smell of gas inside a garage.
As for a charcoal canister, I'd imagine an OE vapor canister would work just fine. It wouldn't be plumbed for vacuum to pull vapors into it, but as l9ng as the vent line that is causing the fumes in the garage is connected to the canister, the fumes will have to pass through the activated charcoal.
I'd source one from a 'yard, from a small car/engine so it would be compact. Refresh the charcoal if needed, run the vent line into it and you're done.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 11-21-2012, 07:39 PM
S10 Racer's Avatar
http://www.warsprints.com
The Smell is Gone!
Glad you got smell fixed. If it had been me, I would have gotten a new wife. LOL
The Following User Says Thank You to S10 Racer For This Useful Post:
Old 11-23-2012, 02:00 PM
I have a coil of tubing in my vent line just above my tank, that doesn't seem to help. Someone on the H.A.M.B. suggested attaching a fuel filter w/1/4" fittings to the vent line so the tank could breath. That seems to help, but it's not the cure all.
It was also suggested to run a vent line as high above the tank as I could and create a 180 then back down, kind of like a upside down J trap. I don't see how that would make any difference.
Again, the fuel filter on the end of the vent line does seem to help!
ANY OTHER IDEAS?????
Thanks! Joe
Old 11-23-2012, 02:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
?? Vent it through a activated charcoal canister...
Old 11-23-2012, 02:16 PM
I tried that. I took a small radiator overflow tank and filled it with activated charcoal, starting smelling gas after a short while again. Besides, if you don't have a way to purge the fumes from the tank, seems like you've just built a bomb!
Old 11-23-2012, 02:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're still smelling fumes after passing these fumes through an activated charcoal canister, a few thoughts come to mind- since a correctly sized fresh activated charcoal filter will remove gas smells:
the canister isn't big enough, or has old, gassy charcoal in it
the fumes are coming from the cap or some other place than the vent line- like a cracked rubber connection between any of the gas or vent lines to the tank
As far as a bomb goes, most any gas tank has an explosive atmosphere inside it. Using a charcoal filter is less of a hazard than venting the fumes into the air I would think.
Old 11-24-2012, 02:46 PM
OK! Here is what I have and have done today! Hope the hell it works! I used a puke tank and screened the lines inside and filled it with activated charcoal and attached it to a fuel filter and then on to the curley-q on top of the tank!
ID:	69332   Click image for larger version
ID:	69333   Click image for larger version
ID:	69334   Click image for larger version
ID:	69335   Click image for larger version
Old 11-24-2012, 08:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't know if it'll work (I do think it will), but that's a hell of a clean installation! Nice job!
Old 11-25-2012, 03:57 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
My wife has complained for sometime now about the gasoline smell in the garage, !
Your a better man than I, I would have told her to go in the house. Nice work anyhow
Old 11-25-2012, 04:55 PM
OK! This was this mornings project. Still smelled gas, off came the canister.
I came off the curley-q with 3 loops as high as and behind the tank.
Then I dropped through the floor and attached a fuel filter with 1/4"
fittings then from the filter a 3' line terminating in the frame rail.
This afternoon it was 84 degrees---No smell!
ID:	69379   Click image for larger version
ID:	69380   Click image for larger version
Old 11-25-2012, 06:08 PM
smelly garage
looks like a pretty neat hot rod.
Garage floor coatings, Blackdog's garage Blackdog Garage - Tools 1 01-09-2012 02:30 PM
DID Garage Junkies get morphed into the Garage Journal? Rob Keller Garage - Tools 0 12-06-2008 09:11 PM
roller tip to valve tip alighnment eliot Engine 5 07-31-2007 12:33 PM
Tip of The Dy #50 jcclark Body - Exterior 0 05-17-2006 06:57 AM
Just a tip daimon1054 Body - Exterior 6 03-05-2005 12:42 PM
