tip in vacuum switch 85 chevy c10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2010, 12:56 PM
fast68's Avatar
likes chevy trucks & boobies
1985 E4ME vacuum ports...
the vacuum tip in switch mounted on firewall up high to pass side of the engine is the vacuum line source supposed to be from ported or from full time vacuum
having a hard time following the emissions label vacuum diagram with all the thousands of hoses and crosses and connections on it
what does this switch do anyways
does it mean tip in as to when you just barely tip open the throttle or?
so that would mean its meant to be run off ported source right?
its the 4.3L VIN N 4bbl oddball truck that 1985 had
ok update, i studied the label some more and think i have most figured out,
looks like port N is for the tip in.
J and H combine to a vacuum motor thing and some Tees to run to the vacuum advance distrib diapragm. should i run it to full time source since this EST system has advance weights for later on timing advance?
and T goes to charcoal canister hmm
right?
thanks
Old 10-21-2010, 01:16 PM
sqzbox's Avatar
My pipes are my music
If it's anything like my 88 305 it would be a vacuum control module for the EGR valve. It keeps the EGR from operating in open loop untill the engine gets to operating temp. and goes into closed loop.
Chevy 305U how to measure vacuum rack Engine 19 07-22-2008 09:58 AM
84' Chevy C10 Blinker Stays On Gokussj5okazu Electrical 11 11-17-2006 05:30 PM
85 Monte carlo vacuum setup 85MonteCarloSS Engine 2 09-03-2006 11:16 AM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
Chevy SB vacuum advance jpsage Engine 3 04-01-2002 08:05 AM
