tippy toed falcon - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2007, 05:32 AM
tippy toed falcon
Installed new upper and lower control arms 1963 .csrc disk brake kit, now it stands on its tippy toes. I-6 coil springs.I-6 144ci engine .rolled back and forth wont come down.any ideas
Old 04-24-2007, 09:35 AM
Did you tighten down the control arm bolts?
Loosen them back up and BOUNCE the front end a few times to get things settled then you can tighten them back up.
Old 04-25-2007, 05:13 AM
tippytoed falcon
1962 falcon .63 upper and lower control arms.falcon parts.com garanda disk brake kit csrc. loosened upper control arm bushings lower control arm bolt to body removed shock. tried bouncing stiff as aboard.rolled around garage didnt help.compresed spring arms came up.I-6 original spring .engine and tranny are in car.
What do you think of a 63 straight axle Falcon? 63' Falcon Gasser Suspension - Brakes - Steering 23 12-19-2013 10:16 PM
1962 Falcon disc Brake conversion???? RUDY Suspension - Brakes - Steering 3 01-23-2012 07:33 AM
Hi there Im Josh with Rudy the 62 falcon RUDY Introduce Yourself 3 01-12-2007 02:55 PM
Falcon davenj Introduce Yourself 2 01-16-2006 05:53 PM
Ford Falcon EA-Carburettor or EFI?? stonecold42 Hotrodders' Lounge 4 12-07-2002 02:25 PM
