Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tips for 2k seam sealer application?
Old 06-11-2012, 08:20 PM
Lizer Lizer is offline
I've just started adding some Pliogrip #6 low sag 2k seam sealer on the Mustang. Right now I'm doing the old fashioned smooth out with the finger trick then wiping any ridge down/away with a paper towel. After it set up I tried sanding it down with a red scotch brite but I can't help but think there are probably some better ways for me to do this, or even tips or favorite methods that some of you guys have.
I got one of my modeling brushes to try but by that time I had the gun setting around too long and it set up in the tip, so I just stopped for the night and will do some more later after I have more seams prepped so I get the most use out of a new tip.
