Tips And Advice For Buying Used Heads - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-24-2011, 01:56 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Hoyt71
Any way to check for cracks other than hoping I can see them?
Most any well-equipped automotive machine shop can magnaflux cast iron or steel for you. Aluminum requires a different process called Zyglo. I'm sure there are newer procedures that I may not be familiar with yet.
How do I tell runner size?
Same way you measure combustion chamber volume, with a burette and colored fluid. Here are a couple of sites to learn from...
http://www.circletrack.com/techartic...s/viewall.html
http://www.hydrostream.org/ArticleArchives/CCHeads.htm
Metal Lathe for Hobbyists: Buying Tips and Recommendations lt1silverhawk Garage - Tools 38 07-30-2011 08:27 AM
tips on buying a used lathe jss Garage - Tools 9 04-05-2010 06:17 PM
ECM buying tips ET1wilson Electrical 4 12-01-2009 08:47 PM
Advice on buying new rearend... 83elky Transmission - Rearend 10 03-15-2008 09:09 AM
E-Bay buying tips EastCoastSBC Hotrodders' Lounge 11 03-23-2006 07:56 PM
