Tips on bulding the framework for fiberglass doors on a 34 ford coupe? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2009, 07:59 AM
Hi guys. does any one know where i could find any info on bulding the framework for fiberglass doors on a 34 ford coupe? or what kind of books i need to get for this type of project. any help is always appreciated.. thanks...Jim from missouri
Old 01-29-2009, 08:07 AM
Wiki Edits: 27
doors
If you are going with metal check out chris's project. google chris davenport willys. a lots of picts of his build at the college shop.
Old 01-29-2009, 08:18 AM
Well metal frame for the inner and outer doorskins.
Old 01-29-2009, 06:54 PM
boatbob2
Huh????????
Hi,what are we building,metal doors? or fiberglass doors? do you have any door parts or only a hole where the door goes?? be specific on what youre trying to do.then im sure we can help you.
Old 01-30-2009, 08:18 AM
Its a friends project he is starting with only the inner and outer fiberglass door skins. and we are not sure what to use or how to do the right way. or where to find good literature for this type work
Are 37 - 40 Ford Coupe Doors the Same 37FordCoupe Body - Exterior 8 12-28-2008 11:44 AM
35 Ford Coupe front clip on 35 Ford truck 35hotrodtodd General Rodding Tech 8 12-27-2007 02:00 PM
Did Ford make a 3 Window 37 Coupe 37FordCoupe Body - Exterior 2 07-22-2007 08:26 AM
35-36 ford coupe deck Footstomper Body - Exterior 11 06-08-2007 06:39 PM
1930 Coupe Doors? SuperFrog Body - Exterior 3 03-06-2004 04:53 AM
