Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tips on C-4 Rebuild
Old 06-12-2008, 09:24 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
inspect the converter for leaks too. cracked hub, loose drain plug, cracks at the threaded studs for the flex plate.
