Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tips for getting a car to start in below 0* ) weather???
Old 01-03-2013, 06:50 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
If it doesn't start after your 1 to 2 hour charge, do bring the battery in over night or at least leave the charger on overnight, timothale is correct, a battery can freeze quickly when not charged. If you do get it running, let it run for quite some time, not just to get the car good and warm but to put a good charge in the battery...may not be a bad idea to put some gas line antifreeze in it. I don't know how full your tank is but in this cold weather if it's below 1/4 tank that's when gas lines freeze up. Water is lighter than gasoline and has a tendency to hang around the top of the tank, when your tank gets low, your sucking more moisture into your engine and can freeze up easier.
Ray
