Tips on how to fix this hole in my metal dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2013, 04:52 PM
At some point in my VW bus's life someone decided the ignition should be a push button. So now I have this nickle size hole im trying to get rid of.
To start the repair I put some support behind it and first filled the hole with Tigerhair. Then i used a little Bondo Gold a friend had laying around and put a lite layer on to fill the hole smooth. I decided I didnt really like Bondo (no surprise) so wiped it off smooth with some lacquer thinner so I wouldnt have to sand it smooth and hit the paint.
Thats where I am now. I thought before I tried anything else I'd ask some experts and see if theres a good product(s) or technique out there I should try. Its single stage paint so once its done Ill hit it with some paint and hopefully color sand it until it matches.
Name:	2013-01-01 12.17.33.jpg
Old 01-01-2013, 04:57 PM
There is no way that is going to last without having a "ghost line" there. You WILL see it once it's painted. The only way you can fake something like that (not welding it up properly) is to bend in the side of the hole a little so when you spread your filler over it there is a thin layer all the way around the outside. This is still likely going to show a ghost line but you may get away with it.
Old 01-01-2013, 06:47 PM
Personally I would just plug it.
Knock Out Plug by VALUE BRAND - Electrical Box Cover Accessories by Zoro Tools Industrial Supplies
If you want to pay more you can get chrome or stainless.
Old 01-01-2013, 07:46 PM
Honestly, I am going with Chevymon, that makes more sense. Either that or put something there, a switch, cig lighter, something.
Old 01-01-2013, 07:59 PM
If the bus wasnt so pretty I'd put a cap or something on it. The story is so annoying to begin with, we did the entire restoration you see, paint and all. It wasnt until we were doing the electrical did we realize there was one too many holes. The restoration was done in Florida then we drove it to Cali last month so its farrrr away from the shop where there are some proper tools.
ID:	70240   Click image for larger version
Old 01-01-2013, 08:06 PM
Well, putting a cap in it makes more sense than doing it wrong.
Old 01-02-2013, 01:30 AM
If you paint a hole cover the same as the dash color it will look like VW put it in there in place of an accessory switch that someone didn't order.
Old 01-02-2013, 10:16 AM
ogre's Avatar
the 'Duracell Project'
the waterproof/ oil tight knockout cover might look better in there.
you could hit it with a spray bomb and install it.
these have a foam seal and a wing nut on the back to fasten them
you can get these at any home depot WIEGMANN Hole Seal, Oil Tight - Enclosure Hole Seals - 6C749|WAS050 - Grainger Industrial Supply
Old 01-08-2013, 07:58 PM
Perfect location for a cell phone or GPS mount.
Old 01-08-2013, 08:02 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
This is why I love this website. I shop Grainger all the time, never knew about these.
Thanks for the post!
57 belair pot mtl dash to metal dash adsmtz Body - Exterior 1 09-03-2012 07:00 AM
new video up with body tips/ panel alignment tips/ metal working ideas tech69 Body - Exterior 10 05-30-2012 12:49 AM
Fix Hole In Hood pi71 Body - Exterior 4 04-03-2007 06:09 PM
How to fix trunk lock hole? MM in NM Body - Exterior 3 03-06-2006 09:17 AM
how to fix LARGE rust hole??? 1st timer Introduce Yourself 1 10-12-2005 07:59 PM
