Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tips for installing air gap intake
Old 03-30-2012, 08:40 PM
unix unix is offline
Originally Posted by yardman
hi need some advice with installing the air gap from elderblock #7516 i bought the fel pro gasket but its not perfect lineup. and i have to use ATV on the ends of the block.i can tell i will have a leak for sure. is there any advice or a better gasket. maby the elderblock not fel pro...........383 chevy stroker
The manifold says in the instructions to use their gasket set, think I'd do that. I try and stay with matching the hardware and the install items, seems like a logical choice, mix and match is possible. Then the question becomes how many times do you wish to do the same install? You already have one under your belt and the post sounds like it is not working out as you thought. So with that in mind why play around RTP "Read The Poop" and follow the poops instructions, remember they are the R&D of that product.
