Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tips for installing air gap intake
Old 03-31-2012, 07:29 AM
delawarebill's Avatar
delawarebill delawarebill is offline
gasket ??
when u say "ends of the block" ???? are u talking about the front and rear areas that use the smaller rubber gaskets???? if so i think most will advise u use "RTV" instead of the gaskets.. put a good bead and put intake on while its still wet. I use the hi temp RTV with no problems...
