-   -   tips to rotating crank (http://www.hotrodders.com/forum/tips-rotating-crank-226095.html)
mistagoodbadguy 11-14-2012 07:48 PM
Any tips on how to roatate the crank while ur putting the bottom end toghear I have always used the balancer bolt but realy don't want to frorce it is there any tricks to doing it better
BOBCRMAN@aol.com 11-14-2012 08:33 PM
Leave the key in the front of the crank. Use a large Cresent wrench. Set it to just clear the OD of crank snout and the wrench on key will turn the assembly.
Been doing it this way for over fifty years.
mistagoodbadguy 11-14-2012 08:38 PM
Thanks I knew there was some sorta easy way to do it any other ways??
Richiehd 11-14-2012 08:40 PM
There is a special socket available that slips on the front of the crankshaft. I think I got one from Summit. I do like the adjustable wrench method too though.
cdminter59 11-14-2012 11:07 PM
Here is an inexpensive tool to use when you have the balancer off. Proform Crankshaft-Turning Sockets 66901 - SummitRacing.com. If you have the balancer already installed here is another tool for rotating the crankshaft. Proform Engine Rotation Adapters 66782 - SummitRacing.com.
