tips to rotating crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2012, 06:48 PM
Any tips on how to roatate the crank while ur putting the bottom end toghear I have always used the balancer bolt but realy don't want to frorce it is there any tricks to doing it better
Old 11-14-2012, 07:33 PM
BOBCRMAN@aol.com's Avatar
Leave the key in the front of the crank. Use a large Cresent wrench. Set it to just clear the OD of crank snout and the wrench on key will turn the assembly.
Been doing it this way for over fifty years.
Old 11-14-2012, 07:38 PM
Thanks I knew there was some sorta easy way to do it any other ways??
Old 11-14-2012, 07:40 PM
Richiehd's Avatar
JS-70
There is a special socket available that slips on the front of the crankshaft. I think I got one from Summit. I do like the adjustable wrench method too though.
Old 11-14-2012, 10:07 PM
Here is an inexpensive tool to use when you have the balancer off. Proform Crankshaft-Turning Sockets 66901 - SummitRacing.com. If you have the balancer already installed here is another tool for rotating the crankshaft. Proform Engine Rotation Adapters 66782 - SummitRacing.com.
new video up with body tips/ panel alignment tips/ metal working ideas tech69 Body - Exterior 10 05-29-2012 11:49 PM
welding tips/ mixing featherfill tips tech69 Body - Exterior 1 04-16-2011 02:15 PM
use 265 crank for 302/use 262 crank for 312 denny1977 Engine 2 01-22-2006 01:02 PM
Reverse rotating engine Crank question Houman SS '70 Engine 16 04-13-2005 07:55 PM
Scat 9000 crank VS stock 400 crank? MOORESPEED Engine 5 03-03-2005 10:54 AM
