Tips on sewing 4 way seams - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2010, 08:31 PM
ronbo's Avatar
Having a thickness issue at four way intersections of french seams and overlay seams. I've had to cut away some material on the back side otherwise I get high centered.
Any suggestions on how to cut away or how to sew these 4 ways??
Thanks
Old 04-01-2010, 06:45 AM
DanTwoLakes's Avatar
Wiki Edits: 22
About the only thing you can do is stop your machine at these points and use the hand wheel to sew one stitch at a time. Another thing is to make sure your sewing machine is set up for the most fabric thickness it can be set at.
On this sewing machine, it is set at the most fabric thickness when the bolt that is held on with the wing nut is in the lowest spot in the slot it goes through. Your machine should have some way to adjust this. Sorry about the fuzzy focus, but you can see what I mean.
You also should be able to adjust the pressure of the presser feet. Decreasing this pressure should help.
ID:	44848   Click image for larger version
Sewing Machine tips holden Interior 85 10-19-2010 08:58 PM
Short guide on tips and viscosity. cjperotti Body - Exterior 15 06-02-2009 05:17 PM
how to get rid of rust in the seams? glhx Body - Exterior 1 05-27-2009 05:29 PM
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 06:04 PM
