Tire circumference and a Detroit locker - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 02:57 PM
57halfton's Avatar
I have a 9 inch Ford rearend in my Chevelle with a Detroit Locker and Mickey Thompson ET Street tires, size 28x12.50x15 and with 20 lbs of air in them I measured the circumference, the left rear tire was 92 1/8 inches and the right tire was 91 3/8 inches , 3/4 of an inch difference. Will this cause any problems ?
Old 04-29-2011, 03:22 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i would think it will be o.k.
put a pound or two more air in the smaller one and see what happens
Old 04-29-2011, 03:52 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
circle track guys call that tire stagger and run the larger on the right side so they turn in better..Adjust the pressure so they are more equal and yes it is normal to have a slight variation in the tires..
Sam
Any one have a 3.XX-4.XX Detroit Locker? majorownage Transmission - Rearend 1 10-29-2009 08:25 PM
detroit locker or powertrax locker??? elcaminodragster Transmission - Rearend 7 10-13-2009 08:44 PM
Detroit Locker?? lizardking7750 Transmission - Rearend 2 08-07-2009 04:24 AM
detroit locker jgh64pkup Transmission - Rearend 19 03-27-2009 11:11 AM
Detroit Locker henny496 Transmission - Rearend 8 11-06-2005 08:34 PM
