tire height
The most accurate way to find your tires actuall height is still with a measuring tape. And more accurate than chats.
Two tires of the same advertised dimensions doesnt guarentee they are the same height. They could easily be off as much as 1/2 inch or more. Factors here include materials and compounds used in production, temps of the tire when it came out of the mold, how long it maintained those temps, and how it was stored after production, and after shipping and setting on a rack waiting for mounting. Inflation pressures also play a part in a tires diameter.
The most accurate way to find your tires diameter is to measure the circumferance of the tire around the middle of the tread, while inflated to the desired running pressure. Divide that circumferance by pi, or 3.1416, or however far you want to carry out pi.
And dont assume that just because you have a "matched" set of tires, that both are going to be the same diameter as well.
In stock car racing, altering the circumferance of a tire, or rollout, is a trick used to make the car handle better.
The difference in the rollout between the left side and right side tire is called Stagger..
To alter the rollout in a tire, the trick is pumping the pressure up as much as 50 psi in that tire, and let it set in the hot sun all day. Be sure to put the tire under something that would provide protection if the tire desides to explode.
Then go back and measure it after you drop the pressure back down to the desired running pressure. If you have a rollout difference of less than 3/4 inch, or roughly 1/4 inch difference in diameter, dont even mess with it on a street vehicle.
The alternative would be to run the tire at about 10 lbs over the factory speck for a day, then let it back down to desired pressure, and compare. However, in the interest of safety, I DO NOT recommend doing this on a street vehicle. I wouldnt even swell a race tire that way on the track.
One other thing to consider, over inflating the tire in such a manner could easily void out your warrentee.
