Tire issues. HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2009, 08:31 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Tire issues. HELP!
Hello.
Buildin me a rat rod, 54 international Harvester,, 1 ton dually. Got 16 inch rear rims. I want TALL tires for it. I cant anything much that will fit width wise except a couple.
One is a 195/80/16 and the other is a 215/85/16 Wich is going to be taller? Im no good at these metric measurements.
Also, anyone know other sizes thats tall, but thin?? LOL Tnx, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 12-01-2009, 09:34 PM
Wiki Edits: 31
the 215 will be taller and a bit wider
Old 12-02-2009, 02:10 AM
327NUT's Avatar
A 235-85-16 is about 31.5"....all 85 series tires are "E" rated at 80 psi.....not that you have to run that much air in them.
Old 12-02-2009, 09:06 PM
bentwings's Avatar
bentwings
I have 235's o my Dodge dually. They are tall and skinny. Be prepared for sticker shock. $1100 or more.
Old 12-04-2009, 11:53 AM
johnnykool6's Avatar
johnnykool6 / fast unlimited
Last journal entry: Blown S-10 for sale
I can tell you what NOT to use! I'm running 265/75-16's bridgestones, and they almost touch each other!
Old 12-04-2009, 01:48 PM
I had this problem with 255/85-16s on my Chevy dually. Ended up using spacers from Fred Groeske.
http://www.wheeladapter.com/
Fred's a great guy and previously ran a rocket-powered funny car. His spacers are high quality and he takes great pains to ensure that the hub-centric feature is maintained on trucks that use it.
Old 12-04-2009, 04:19 PM
Looks like they'll do the trick for me! Thanks Joe!!
Old 12-04-2009, 07:21 PM
Kool.
Thanks. Im looking at sum 225 85 16's. Are these fairly tall n narrow? HG
tire size vs top speed? sexypizzaman Hotrodding Basics 16 09-12-2014 04:47 PM
tire performance curves BrandAM Suspension - Brakes - Steering 1 02-25-2009 03:18 PM
how muuch tire width do you really need 53LEDSLED Suspension - Brakes - Steering 5 09-08-2006 05:09 AM
Flat tire story. Ghetto Jet Hotrodders' Lounge 8 03-18-2006 12:01 AM
Tire size and posi problems? killerformula Suspension - Brakes - Steering 5 04-12-2004 06:38 PM
