tire paint - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-22-2007, 09:10 PM
Answer to whitewalls, THE SOLUTION
Orn has what seems to be an
o
k solution.....'cept one has to work hard and do the process over soon.....I have a whitewall solution that will soon be open to the public, been in use for 30 years, never any browning problems or cracking and peeling problems.....people in the United States have been getting it done for over 40 yearsand I have been doing it for 28 years,.....check *********************
Last edited by cboy; 10-23-2007 at 07:14 AM. Reason: Advertising. Please see: commercial posting guidelines.
  #17 (permalink)
Old 10-22-2007, 09:42 PM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
I painted my wide whitewalls with white spray paint from Napa. I put on 3 coats of primer, let dry good and then spayed on 4 coats of flat white. After this was dry i spayed on a satin clear coat. This paint has been on for 2 years now and still looks new. Just dont hit the curbs.
  #18 (permalink)
Old 10-23-2007, 06:01 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Please read the site policy on commercial advertising.
  #19 (permalink)
Old 10-26-2007, 11:01 PM
Art Deco's Avatar
Paint your whitewalls if you like, but PLEASE dont grind the sidewalls. If you do please dont drive anywhere around me or my family. White sidewall rubber is inherently weaker than black rubber. It doesnt need anymore help from a grinder. Dont believe me about the white rubber? Take a good look at any racing tire. The white letters are painted on. Next time you get to see a white letter street-tire that has experienced a blowout notice how much worse the white side looks in comparison to the black side. Tires were made of white rubber in the early part of the century until Mr Goodyear learned how to use carbon black in the rubber compound.
I have only heard good things about the stuff from Iceland.
-my 2 cents
  #20 (permalink)
Old 10-27-2007, 08:17 AM
tirepaint
Originally Posted by customtire
whitewall tire r easy to make if you have a cosmo G-3000....this machine does all the work, makes a perfectly round whitewall, and the liquid rubber I use stays white for the life of the tire usually.....at least it has for me for 27 years now
Hi, I'm a owner of the Cosmo G-3000 and surching for the paint en brush were they did put the paint on the tire. Do you know if this is still available?
Thanks, Petje
  #21 (permalink)
Old 11-02-2007, 10:38 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I'm sure a street tire with the side ground a bit is still way stronger than say a DOT bias ply street slick, which are legal for street use and plenty of people run. Personally I don't like whitewalls.
http://www.youtube.com/watch?v=xkcm3rh60p0
http://www.jalopyjournal.com/forum/a...hp/t-5766.html
http://www.jalopyjournal.com/forum/s...ead.php?t=8249
  #22 (permalink)
Old 05-21-2011, 04:42 PM
It's clear to me that their is no clear answer as to the best way to paint a whitewall however I will be undertaking a white wall project and I am very currious how can I mask the tire to get a perfectly radiused edge?
  #23 (permalink)
Old 05-29-2011, 10:20 AM
Any ideas on this?? perhaps cut a template out of tag board with a knife on a compass ??
  #24 (permalink)
Old 06-01-2011, 07:16 PM
No ideas yet?
Or no interest in this topic?
urethane and polyurethane dwhitt Body - Exterior 24 12-28-2012 08:04 AM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
Basic of Basics - Choosing a color Centerline Body - Exterior 1 11-26-2005 09:12 PM
Paint choice? daimon1054 Body - Exterior 2 10-29-2003 11:02 AM
