Tire to rim newbie question
Without thinking I ordered 2 tires I was hoping to put on the back of my 78 Monte.... The size of the tires are 245/60/14, I was hoping to keep the stock look (using the stock rallies that orginally came with the Monte) but have fatties on the rear. When I went to have them mounted the guy said I do not suggest mounting these tires on these rims as he believed they were 14 by 6 in rims. Now I have these tires and no rims to mount them on... Can I get stock rallies like those that came on the Monte in a wider rim? And what size rims do I need to properly mount a 245 tires? Will a 7 inch rim work or does it need to be a 9? I quess if I can get them I will go with aluminum Slots, but I was really hoping to keep the stock rims. Any help would be appreciated. Thanks, Sleeper
The 245 will mount on a 7" wheel with no problem. I am not sure if the factory ralley was a 7" or 6", I had a couple of sets at one time and I don't think I ever measured them.
Is the load capacity sticker still on the door? it will have the standard and optional wheel sizes. |
Wheels vintique I believe makes a wheel that matches the GM rally wheel..and it is available in different widths..
Sam
Sam
You can check with a place like Stockton Wheel. They can usually custom build a set/pair using original centers on new rims. Make sure you take carefull measurements so you can tell them the correct back spacing you want. I've had this done a couple of times.
Thanks for all the help and advice... Found exactly the rim I was looking for...
wheelvintiques rally rim This site is pretty sweet!
| Newbie Paint Question | alf1096 | Body - Exterior | 8 | 06-13-2005 05:22 AM |
| measuring rim width | cboy | General Rodding Tech | 5 | 11-12-2004 09:44 PM |
| Newbie with traction question?? | 1970coupe | Suspension - Brakes - Steering | 6 | 08-28-2003 02:52 AM |
| Newbie question here...but not totally ignorant person :) | Beau Cauchemar | Engine | 13 | 03-14-2003 02:20 PM |
| Question about crank quality, newbie of sorts. | Redjuice | Engine | 3 | 07-13-2002 01:30 PM |
