Tire and rim size suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2005, 12:08 PM
Z-Money Pit's Avatar
I have decided on a set of American Racing Torq Thrust II's for my 1953 Ford F-100 truck. I am interested in a 15 inch rim. What width should I go with. They have one rim that is 7 inches wide and the other is 8.5. What tire size do you think would go with each width?
Thanks for your help.
P.S. I forgot to mention that this vehicle is currently in the process of a frame-off restoration. With that in mind, I am unable to measure any clearances. So, if you have any experience with the 53-56 Ford F-100's (with a mustang II front end), please let me know what should fit. Thanks
Old 06-20-2005, 05:15 PM
broncoII88's Avatar
Do the right thing...
Wider... Is better!
Go with the 8.5's! A wider tire means better cornering and a bigger contact patch.
Old 06-20-2005, 08:54 PM
Fast Orange's Avatar
You've got a lot of unknown variables to determine before you can order wheels-
When you get your rough assembly done,then you'll be able to measure to find how wide what offset and what O.D. tire and wheel combo to use.
You're not telling us what width rear,what front track width,or even what look you're going for,so we can't help you very much.
It's much easier to buy wheels to fit your truck than build the truck to fit the wheels.
I'm not trying to bust your chops here,but I've seen guys buy "perfect"wheels and tires and not be able to use them because they got ahead of themselves.
Good Luck,George
Old 06-20-2005, 09:00 PM
poncho62's Avatar
Wiki Edits: 5
I have 9in wide on the rear with 275-60-15s....fill the rear fenders real nice.
removing tire from rim... brad_irc Garage - Tools 21 10-01-2006 03:32 PM
Rim and tire size needed Z-Money Pit General Rodding Tech 2 06-26-2005 11:03 AM
Best tire rim size / Road & 1/4m drag ? x007 Transmission - Rearend 12 02-26-2005 10:29 AM
biggest rim and tire size for a 55 chevy vin171 Introduce Yourself 1 06-22-2004 07:30 PM
Maximum tire size for a 6" and 7" wide rim? jpd37 Suspension - Brakes - Steering 1 01-16-2004 11:01 AM
