tire size - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2007, 09:12 PM
tire size
on my truck i had tire size 235-75-r-15. i am going to a 16'' rim 7"" wide. what tire size should i use to maintain the same distance travled per one wheel turn to keep the same tac. rpm or lower rpm to get the same gas mileage or better. thankyou i will await your answer.jim
Old 01-04-2007, 09:41 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Your 235-75-r-15 tire is 28.9 inches in diameter. The section width is 9.3 inches and the section height is 7 inches. If you go to a 235-70-r-16 tire your new diameter will be 29 inches with a section width of 9.3 inches and the section height 0f 6.5 inches. Slightly larger circumference and a bit better mileage maybe.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 01-05-2007, 08:44 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Go to www.4lo.com and use the tire size calcualtor to find the approximate diameter of a tire (forget about the "LT" in front, works with standard car sizes) and the gear calculator to determine the rpm/speed of the tire you have, then enter the new diameter to figure out what size gets you closest to those figures. Use "1" for transfer case ratio (1:1). There are other sites with similar calculators, that's just the one that's easiest for me to remember. The gear calculator will calculate whichever piece of data you leave out -- just remember to leave one out.
Old 01-07-2007, 10:24 PM
http://www.dsm.org/tools/tiresize.htm
Plug in your current tire size, then look at the chart for 16" wheels.
Rear tire size for fenderless hot rod. pigmechanic General Rodding Tech 8 08-06-2014 08:29 PM
tire size knighthawk Hotrodding Basics 1 12-19-2006 09:40 PM
question about tire size dboyett General Rodding Tech 7 11-25-2006 07:51 PM
Tire size 85CuttySupreme Hotrodders' Lounge 1 08-06-2004 06:45 PM
gear and tire size Tom Transmission - Rearend 5 01-05-2002 11:29 PM
