tire size - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 09:00 PM
tire size
hey guys i was just wondering what the biggest tire i would be able to go on my 89 camaro rs and it is all stock the rear rims will be 15s and 8 inch wide how big you think i could go??
Old 03-29-2006, 07:00 AM
willowbilly3's Avatar
Last journal entry: Body mods
You could ask the tire store but I am thinking on an 8 inch rim maybe a 265 60. A lot will depend on how tall you want it but stick with a tire that is recommended for the size wheels you are using.
Old 03-29-2006, 07:13 AM
montea's Avatar
tryn to learn
i have a 88 firebird so i might be a bit of help.. maybe.
the widest tire you can fit on a 8 inch rim is 295/50R15. the biggest i would reccommend is 255's depending on your wheels backspacing
215/65R15 is stock on mine, i have used 245/60R14 with no problems, i have also used 295/50R15 with 10" rims and they rubbed on every little bump and cornering slowly so i dont suggest them.
if you got the wheels already with some tires on them you could have the car on the ground and feel around and see how close the tire is to the body everywhere and then you can get a idea of how much bigger you can go, try to keep it a .5-1 inch away from everything and inside the wheel well, if not it will rub when the cars suspension comes down(problem i had with 295's on the back).
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 09:57 AM
Tire size for torq thrust II's sicksixseven Suspension - Brakes - Steering 6 03-13-2005 06:55 PM
Best tire rim size / Road & 1/4m drag ? x007 Transmission - Rearend 12 02-26-2005 10:29 AM
Tire size converter? RObs71Nova Suspension - Brakes - Steering 13 12-11-2004 01:33 PM
Tire size and posi problems? killerformula Suspension - Brakes - Steering 5 04-12-2004 05:38 PM
