tire size chart - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2006, 11:04 AM
stea's Avatar
tire size chart
Anybody have a good tire size chart or a link to a chart. Trying to figure out what size tires will clear my fenders. Need a chart with heights, tread width and overall widths. THANKS
Old 04-25-2006, 12:09 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Every tire manufacturer website has a complete chart for every size they make, including rolling radius, height, width, everything. Since the sizes are standardized, each manufacturer is usually within about 0.1" of each other, except when dealing with actual tread width which can vary greatly. Bridgestone/Firestone has one of the largest selections of available sizes so their website might be the first to use as research.
Old 04-25-2006, 12:49 PM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
Here's a start:http://www.bfgoodrichtires.com/assets/pdf/radial_ta.pdf
This is a good chart for passenger/sport-type tire sizes.
If you're looking for some bigger sizes for hot rods/street rods, go here:https://www.hoosiertire.com/strttire.htm
There are plenty of manufacturers to choose from, but this will get you started.
Steve
Old 04-25-2006, 01:27 PM
stea's Avatar
Just what I needed, THANKS guys
Old 04-26-2006, 02:34 PM
awsum34's Avatar
here's another one
http://www.project33.com/tiresize.cfm
Old 04-27-2006, 11:00 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Sizes aren't as standardized as you might think. There is significant variations in overall diameter (1/2 inch) and section width (1/2 in plus) and tread width (1 inch or more) between brands, lines, and series of tires in each manufacturer's brand as well as from brand to brand. Load rating per tire seems to be the only corresponding value to designated size.
Like camshafts, there are more than one way to measure a tire. Static radius or rolling radius. Section width depends upon wheel width= a tire on a 9 inch wheel will be wider than the same tire on a 7 inch wheel.... by an inch on each sidewall.
I suggest finding a car like yours and see what others are running for wheel sizes and tires. Good luck.
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 09:57 AM
Tire size for torq thrust II's sicksixseven Suspension - Brakes - Steering 6 03-13-2005 06:55 PM
Best tire rim size / Road & 1/4m drag ? x007 Transmission - Rearend 12 02-26-2005 10:29 AM
Tire size converter? RObs71Nova Suspension - Brakes - Steering 13 12-11-2004 01:33 PM
Tire size and posi problems? killerformula Suspension - Brakes - Steering 5 04-12-2004 05:38 PM
