Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tire size and gear ratio
Old 08-17-2005, 08:41 AM
inquiring_mind2's Avatar
inquiring_mind2 inquiring_mind2 is offline
a shade tree mechanic
right now I am using a gm corp 10 bolt with dana axles in the front and a gm 14 bolt in the back. I would like to have a dana 60 but dam those bad boys are not to CHEAP. So for know I will have to stick with the 10 bolt with the dana axles I also got to looking at the transfer case and it is a np 203 not a 208. to much grime on the numbers. lol
I run in low range so will that make a difference? I also run around 6500 to 7000 rpms also
