tire size and gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2005, 01:02 AM
inquiring_mind2's Avatar
a shade tree mechanic
I am in the process of building a new toy. I am building a jeep for a mud bogger. My question is I want to make the front wheels turn faster than the rear ones. I have no clue on how to do this. I am running a 350 turbo for the transmission. a 208 for the transfer case. I would like to know about how to match the gear ratio and tire size to make everything to work properly. Right know I have 4:10 gears front and back. I am also running 35 boggers front and back. I am not wanting to go any bigger than a 35 inch tire. I know I will have to run a smaller one in the front but thats where I need some help. on how to pick the correct gear ratio and the correct tire size. any help would be greatly appreciated
Thanks,
Chris
Old 08-16-2005, 01:15 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Rear end and tire heighth calculators.
http://www.tciauto.com/tech_info/calculators.htm#10
Old 08-16-2005, 08:02 AM
johnsongrass1's Avatar
Race it, Don't rice it!
SO you want the front turning More rpm than the back tires?
You have 4:10's now.
Just put 3:73's in front. Or change the front to a 33" tire.
Old 08-16-2005, 08:04 AM
that won't tear up the tranny or the transfer case
yes that is what I am wanting to do
Old 08-16-2005, 12:29 PM
Yes, it hard on the driveline anytime you aren't in the dirt. But you are going to have to suffer those consequences with a faster moving tire. Even if you gear the front to a 3.73 with smaller tire in front the rpm will remain the same This is defeating the purpose. Or am I not getting what your are asking?
Old 08-16-2005, 11:12 PM
I have seen other people do it. What I am wanting to do is have the front tires pull me through the mud and have the back one push me. I want my front tires to be turning more revolutions than the back ones. at the same time I don't want to hurt my tranny or transfer case either. Am I making sense so everyone knows what i am wanting to do or do I need to try and describe it another way? let me know
Thanks,
Chris
Old 08-17-2005, 03:30 AM
mudbogger
If you use a3:73 and 35's, you will run around 27.5 mph per 1000 rpm in high range top.4;10 and 35's equal 25mph, so you have a10% step up. This will stretch the chain in your 208, and if you are still running a dana 30 in the front it could be an issue. Who cares? blow it up then put a 60 in the front and a14 bolt GM in the rear. By the way, to work out gearing easily, multipy tyre height(loaded) by 2.94, then divide by overall gear ratio (my formula) it will get you within 2%.
Old 08-17-2005, 05:45 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I've seen this done before, and it works.
You are aiming to go as straight and as fast as possible in MUD, the easiest way to acheive this is to have the front tires spin faster than the rear.
I agree with just switching to 3.73's, or the tire size to acheive the same result.
I have only seen one truck owner match the gearing correctly and have the guts to run 40 inch tires in the rear and 33 inch tires in the front, and he deliberately ran a stock NP-203 transfer case to allow the internal differential take care of any gearing differences he might have.
The truck was mostly for show but he wasn't afraid of hosing off a few hundred pounds of mud if the occasion popped up, and someone called the truck a trailer queen.
Old 08-17-2005, 07:38 AM
LOL, I've been into rockcrawling for years, what you want is impossible unless you are ONLY driving in gooey mud, If you have any traction, your T-case is not going to last.
Old 08-17-2005, 08:35 AM
that is all I am using it for is in the mud. I want to go as straight and as fast as I can in the mud.
Old 08-17-2005, 08:41 AM
right now I am using a gm corp 10 bolt with dana axles in the front and a gm 14 bolt in the back. I would like to have a dana 60 but dam those bad boys are not to CHEAP. So for know I will have to stick with the 10 bolt with the dana axles I also got to looking at the transfer case and it is a np 203 not a 208. to much grime on the numbers. lol
I run in low range so will that make a difference? I also run around 6500 to 7000 rpms also
Old 08-17-2005, 09:57 AM
I've got a mud toy based from a 79 jimmy 3/4 ton. All stock driveline cept for welded lockouts. I've got siped 40" gumbo's and run 300 rpm faster in front to stay on top of the mud. Most times I find, you lose wheel spin and momentum by hitting the wall of mud left from the previous guy who got stuck. This will bury the front.
Judging gear ratio with tire size? gpeak Hotrodding Basics 2 06-27-2004 11:27 PM
Gear ratio question RiceMuncherdude Transmission - Rearend 3 04-10-2003 09:45 PM
RPM, GEAR RATIO , TIRE SIZES, EQUATIONS zonk Transmission - Rearend 1 01-08-2003 10:16 AM
gear and tire size Tom Transmission - Rearend 5 01-05-2002 11:29 PM
