tire size / speedo calabration - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2006, 03:03 PM
my truck runs stock 195/75/15 's how many miles per hour off can i expect my speedo to be if i put 32 inch tires on it
Old 07-15-2006, 04:08 PM
50 chevy p/u's Avatar
autoglass master tech
This is a educated guess, but I would say it will be 10 mph slower. You can buy adapters for the speedo that correct this problem also you can change gears on the speedo drive. Don't know which color to use but if you do a google search on speedo drives you could probably find what you want.
Old 07-15-2006, 05:23 PM
My calculations say your 195/75 15 tire is about 26.5" in diameter. A 32" tire is approx 20% larger in diameter, so I think your speedometer will be about 20% slow. (IE: at 50 MPH your Speedo will read 40MPH, etc)
Somebody correct me if I'm wrong.
JA
Old 07-15-2006, 05:24 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Check the knowledge base, I think that there are mileage calculators available.
Old 07-15-2006, 09:06 PM
i got a 80 in a 65 speeding ticket i thought i was going maybe 67
Old 07-15-2006, 09:09 PM
xntrik's Avatar
OUCH
Checking your speedometer with a GPS or having a trooper radar you will let you know how much correction you need.
I have NEVER had any officer/trooper refuse to radar check me. I just find one that is stopped, explain what I need, and they do it.
As far as your calculating it, measure the circumferance of the old tire and the circumferance of the new tire. simple math will tell you.
What size tire is for my 71 Chevelle KFXrider88 General Rodding Tech 2 06-26-2006 06:15 PM
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 09:57 AM
Tire size for torq thrust II's sicksixseven Suspension - Brakes - Steering 6 03-13-2005 06:55 PM
Tire size converter? RObs71Nova Suspension - Brakes - Steering 13 12-11-2004 01:33 PM
Tire size and posi problems? killerformula Suspension - Brakes - Steering 5 04-12-2004 05:38 PM
