Tire sizes!?!? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2004, 09:11 PM
Tire sizes!?!?
This did'nt really fall under any catagory here.
Whats the deal with the inches in dealing with tires sizes.
For example, my amigo has two standands:
225/75/15 and
31x10.5x15
Now I have converted these every way possible but the numbers dont come up right. Like if those numbers were normal mm, it would be a monster truck tire at a size of 787/266/15 in mm.
So someone please help me!? I can't seem to understand this "new" (at least to me) standard for tires.
Basicly what would 225/75/15 equal in that.... other standard.
Old 10-17-2004, 09:26 PM
arch's Avatar
My bike has 4wheel disc brakes
its not directly comparable....
225x75x15 isnt
31x10.5x15
A for A, B for B, C for C...
225mm is the width of the tire = 8.85"
75mm is the height of the tire (between the rim and the tread) =2.95"
and 15" is the rim size
31 is the overall diameter (ie 8.85+2.95+15=26.8)
Obviously not the same tire?
10.5 is the width of the tire compareable to the 225mm although a 10.5" tire would be 265mm (or 10.43")
That help?
Old 10-17-2004, 09:47 PM
sbchevfreak's Avatar
Licenced Automotive Technician
On a P225/75R15 the P means passenger, the 225 is section width in mm, the 75 is the aspect ratio (not in mm, a percentge of the section width), R is radial, and 15 is the rim diameter in inches.
Check out this site, it has apretty good explanation
http://www.apa.ca/template.asp?DocID=94
Old 10-17-2004, 09:56 PM
225x75x15 isnt
31x10.5x15
That help?
Thanks arch, now I understand that inches standard, sorry about all that, but no site I found had the answer.
This thread can be moved to the dump now.
Thanks again arch!
Old 10-18-2004, 01:33 AM
arch's Avatar
no prob
