Tire studs removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2008, 01:15 PM
whatwouldscoobydo's Avatar
Tire studs removal
Does anyone know of a easier way to remove slightly used tire studs,other then a screw driver or dikes?Do'es somebody make a tool? Tom
Old 06-20-2008, 05:54 PM
Vicegrips.
Shane
Old 06-23-2008, 07:49 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I just use a pair of diagonal wire cutters, push the tips into the tire around each stud, squeeze and pull, sometimes a slight twist is needed, and sometimes a second or third try is also needed.
Wheel Studs - Removal & Installation leejoy Transmission - Rearend 8 06-10-2008 11:32 AM
Front face of tire dismounted from wheel while cruising !!!!!!!! Calderone Hotrodding Basics 7 06-05-2008 06:20 PM
A Tire Happenings Synopsis hobbytires General Rodding Tech 21 12-03-2007 06:18 PM
Anti-seize on lug studs??? Bryan59EC Suspension - Brakes - Steering 38 10-07-2007 05:43 PM
32 ford wires (Tire removal) redsin Hotrodding Basics 2 09-12-2006 07:20 PM
