Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tire wear
Thread: tire wear
Old 11-11-2012, 12:01 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
what 69 said, also bearings are checked to make sure they are not loose,tires must be in good shape with matching sizes,air pressures must be set.Your caster and camber changes when the tires are turned but remain constant when driving on the highway. If you had worn parts,you didnt get a 3 axis wheel alighnment
