Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tire wear
Thread: tire wear
Old 11-11-2012, 05:25 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
take the tie rod ends and check them for movement,or squeeze them with your hand if you have a good grip.Jack tires about 2 inches off the ground and put a pry bar under each one and lift,see if ball joints have movement. Check your pitman arm similar to idler arm. and centre link.Fix all the problems
