tire wear - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2012, 10:23 PM
whojohnjones's Avatar
tire wear
OK on my 1983 Buick park avenue my car tires have been having excessive wear and goes from negative to positive chamber. OK one guy said it was control arm bushings. so he replaced those now i have to get a alignment but once i brought the car home and jacked it up i noticed if i shook the tires from left to right i could see the idler arm go up and down is this normal and what would cause this?
Old 11-09-2012, 11:34 PM
Old 11-09-2012, 11:35 PM
posted youtube video
Old 11-10-2012, 09:30 AM
RWENUTS's Avatar
Idler arm is worn out. Easy fix. Replace it.
Old 11-10-2012, 09:44 AM
Faith - Respect - Trust
How could you get a proper alignment with a worn out idler arm? Anytime I've done an alignment I've checked all front end parts for wear, ball joints, tie rods, bushings, bearings, spindle and the straightness of the frame all play into getting a proper alignment. I would take it back to the guy that did the alignment and ask questions, my first question would be how he could do an alignment with worn parts.
Ray
Old 11-11-2012, 01:01 PM
vinniekq2's Avatar
what 69 said, also bearings are checked to make sure they are not loose,tires must be in good shape with matching sizes,air pressures must be set.Your caster and camber changes when the tires are turned but remain constant when driving on the highway. If you had worn parts,you didnt get a 3 axis wheel alighnment
Old 11-11-2012, 06:18 PM
I haven't had a alignment yet...I was told by last mechanic that control arm bushings was all the problem was..when I shook the tire and didn't seem right I just wanted to make sure there was more to the problem
Old 11-11-2012, 06:25 PM
vinniekq2's Avatar
take the tie rod ends and check them for movement,or squeeze them with your hand if you have a good grip.Jack tires about 2 inches off the ground and put a pry bar under each one and lift,see if ball joints have movement. Check your pitman arm similar to idler arm. and centre link.Fix all the problems
Spare tire on staggered tire setup..Front or Rear?? Dilbert Hotrodding Basics 6 05-20-2012 04:54 PM
How often do hooks wear out? Qwerty27807 Interior 3 02-26-2012 11:07 PM
tire wear??? gofastz Suspension - Brakes - Steering 10 01-19-2011 06:51 PM
tire wear and posi traction voodoosurfer Transmission - Rearend 5 05-17-2005 08:35 PM
Premature Tire Wear Dave E Shank Suspension - Brakes - Steering 7 10-15-2003 11:15 AM
