Tire width and rim width??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2005, 10:46 PM
I have a pair of 275/50/15's that I would like to have put on my stock steel rims (1970's ish ford rims) I am not sure of the rim width I think 6-6.5. but according to summit, recommended width is 7.5-9.5. could this work on this size rim or what would be the dangers by mounting on a thinner rim than suggested. thanks in advance
Old 11-09-2005, 12:31 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Wheel width should be matched pretty closely with TREAD width of the tire.
Old 11-09-2005, 12:54 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
You're going to waste quite a bit of that expensive tire. It will not deliver the performance or the tread wear that it should because it will be distorted. The sidewalls will be tapered toward the beads more than they should, resulting in more squirm, more wear and more lag between steering input and actual change in direction. The tread will not lay as flat as it should, resulting in less traction and uneven wear. If you under-inflate it to get rid of the center bulge the narrow wheels cause, it will overheat quicker, respond slower and wear faster.
Rim and tire size needed Z-Money Pit General Rodding Tech 2 06-26-2005 11:03 AM
Tire and rim size suggestions Z-Money Pit Suspension - Brakes - Steering 3 06-20-2005 09:00 PM
measuring rim width cboy General Rodding Tech 5 11-12-2004 09:44 PM
Looking for help choosing correct rim width. bigfred1958 Suspension - Brakes - Steering 1 08-12-2004 12:15 AM
Maximum tire size for a 6" and 7" wide rim? jpd37 Suspension - Brakes - Steering 1 01-16-2004 11:01 AM
