Tired of GM alternators - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-19-2013, 06:51 PM
EOD Guy's Avatar
To answer your wuestion: Yes you can tie it into the pos on the batt, but the sense wire will see a steady 13v from the battery and may not work as well as splicing the #2 wire into the feed just before it goes into the fuse block. No need to cut the feed wirem just strip back the insul about 1 inch, use a screwdriver to pry apart the strands, about 1/2 of the strands on each side of the blade, push the new wire thru the opening in the strands and wrap tightly, apply some solder and put on some liquid elec tape...... nice secure splice.
  #17 (permalink)
Old 05-20-2013, 07:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by kleen56 View Post
I appreciate this info... Most of these alternators you mentioned run a serpentine belt. Unless the pulleys are interchangable, I prefer to stay with the V belt drive than change out all the pulleys.
Pulleys for V-belt on CS series alternators are available. For example: 1 Groove V-Belt Alternator Pulleys. Stock V-belt pulleys can also be used, if the fan blades are directional they should match the rotation of the alternator.
  #18 (permalink)
Old 05-20-2013, 09:20 AM
I've done it using the stock pulley from the old alternator with no problems. Don't get me wrong, I like the CS130 for a few reasons. It's smaller and lighter than the SI family, has higher output, and has the separate field terminals that allow you to hook it up either with an idiot light or without - the external resistor is not needed. The two downsides are the cost of rebuild parts and the need to ensure a good ground to the rear frame. The second ex-wife had a stock CS130 in her Buick and the alternator would go bad every 12 months. After the third replacement I finally found the TSB that called out the need to add a ground strap from the rear frame to the block. Turns out that corrosion between the aluminum end frame and the steel stator core blocked the ground path for the regulator, causing it to fry. The strap fixed the problem (well, until she left, but that's a story for another forum...). Note that most cars that use the CS alternators have a bracket that bolts to the rear frame, acting as the ground path.
The Following 2 Users Say Thank You to joe_padavano For This Useful Post:
35WINDOW (05-20-2013), cobalt327 (05-20-2013)
alternators??? fink18 Engine 5 07-04-2012 08:32 PM
Alternators... hallamwillis Electrical 5 09-05-2006 12:08 AM
1 wire alternators.... Crazy Mopar Guy Electrical 36 04-09-2006 06:37 PM
alternators durand Electrical 3 01-21-2005 12:22 AM
Alternators Rodder Electrical 15 09-15-2003 07:57 PM
