tired of tbi - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2010, 12:30 AM
tired of tbi
hey guys got a 90 chevy pu want to do away with the tbi and go back to carb and hei how hard will this be and will it make for a better running motor???
Old 06-20-2010, 02:22 AM
techinspector1's Avatar
Wiki Edits: 326
Sounds like a horrible idea to me. Could result in huge fines and the inability to sell the truck to anyone who has to pass emissions anywhere in the country.
Sell the truck and buy an earlier year vehicle to dink with, one that is not subject to emissions testing.
Old 06-20-2010, 04:36 AM
Race The Truck
Last journal entry: Son's Truck
Whats the problem? www.fullsizechevy.com
Craig
Old 06-20-2010, 08:13 AM
shouldnt be a big deal, just have to get the new style intake manifold with diagonal bolts,look for one from the newer style motor with the centerbolt valve covers, should bolt right on.
Old 06-20-2010, 09:38 AM
dont have testing here yet.
no real problem just dont like all the computer controled crap
Old 06-20-2010, 11:21 PM
thats it nothing else??
Old 06-20-2010, 11:43 PM
"thats it nothing else??"
which transmission does it have?
high pressure fuel pump for the TBI?
Electric speedo? Evap canister? Air injection for the exhaust and cat?
They are all linked together and the ECM won't work without the TBI in the system. Changing out ALL of the wiring harnesses won't be fun or easy, the electronics are not backwards compatible.
Sorry but I think techinspector1 nailed it, much easier to find an older truck to play with.
Old 06-21-2010, 11:49 AM
truck has 700r4 out of a chevy mini van, no cats 3in pipe into flowmaster w/dule outlets, looks like older style exuast mans,also looks like someone has been in ecm. truck runs pretty good i'm just not that up to date on all the computer stuff nor do i have the budget for it oh no speedo hooked up at the moment its elec.
Old 06-21-2010, 09:50 PM
"truck runs pretty good i'm just not that up to date on all the computer stuff nor do i have the budget for it "
Than just leave it alone, there is no cheap & easy way to convert, the ECM also ties into the 700R4.
IF you can find a pre 87 Astro van with a 305/350 & 700R4 with a non-electric carb, grab it up for the parts, harnesses and ECM and plan to send a week changing things over, then pray for the best.
Changing over to a CCC carb makes no sense, just as much computer control and more expensive. For giggles I just checked NAPA for parts:
a Holley rebuilt E4ME Q-JET is $700
Echlin rebuilt parts for mine is $250 + a weekend tinkering around
off-brand parts are $150 and questionable
This really does sound like an idea that should die on the vine, sorry.
Old 06-21-2010, 10:11 PM
i think we missed the point dont want to convert ecm want to do away with all the computer crap, no sensors ect.ect
Old 06-21-2010, 10:27 PM
FastOrange's Avatar
Im successfully running a Carb 350 and using the factory 4.3L PCM to control my 4L60E, no problems what so ever, and i didnt get it tuned
Old 06-21-2010, 10:28 PM
FastOrange's Avatar
easiest way around the TBI Pump is to use a Holley By-Pass regulator.
Here is the info on how i did it.
http://www.gmt400.com/forum/showthre...-4L60E-Control
Old 06-21-2010, 10:37 PM
FastOrange's Avatar
plus in 1990 your tranny should be a 700R4. making this swap super easy, basically all you need is
-Holley ByPass Regulator (http://www.summitracing.com/parts/HLY-12-803BP/) Has to be bypass if you plan to keep the TBI Pump.
-Carb Intake
-I would recommend a HEI Distributor
-Carb
Steal the 12V for the Distributor from the Pink wire in the stock coil harness. '
Keep the CTS, VSS, OPS so your gauges work.
Old 06-21-2010, 11:21 PM
thats what i was thinking carb,intake,hei, also thought about dumping the r4 going to th400
http://i935.photobucket.com/albums/a...7/truck002.jpg
this is my driver/toy that i want to spruce up. thanks guys for any thoughts.
Old 06-22-2010, 01:28 PM
FastOrange's Avatar
Nice little Sport!
if you are going to a TH400, i dont know if your speedo will work right.
Need some help with 1986 GM 305, TBI or Carbed??? dieselcruiserhead Engine 8 12-19-2010 07:32 AM
Tired BBC stumbles...ECU, TBI...HEI? unstable Engine 2 05-01-2010 01:15 PM
TBI assistance needed jack kelley Engine 5 05-24-2006 10:11 AM
Tbi Mods NAIRB Engine 8 05-03-2005 06:50 AM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 01:42 PM
